14 years agoelf process failed
I am trying to run Altera 10.1 NiosII on Win7 64bit. I have the following errors when I try to implement a simple Hello world program: Downloading ELF process failed No byte stream services fo...
14 years agoHi, you have to first configure/download the fpga with :
* set the board to a standard config, by pressing the good switch if you work in an Altera development board. * or download your design containing a Nios and SOPC to FPGA (the .sof or .pof file). Read the "getting started" manual On 64bits Windows, you need to install good drivers if you use USB Blaster, see in the forum. Good luck !
