11 years agoEfficiency and combining of powerSoC
Dear All,
Can some please answer my questions below. In the design I'm currently working on, we are going to use the Cyclone V GX. I'm looking for a suitable power supply for this part a I found the powersoc website. My system is battery powered (10Volt) and for that reason only a handfull of the powersoc's can be used. The disadvantage of these situation is that the high VIN/VOUT voltage difference leads to a lower converter efficiency. It is clear to me that I need to stay within the 30mV accuracy for the FPGA core voltage, this can be done with the EN2360QI. This part has a 2% accuracy an the ripple can be brougth down to about 7 mV (optimum) But the efficiency is only 83% and dropping fast below 1,5A. Is it possible to combine two DC-DC converters to get a better efficiency, so let's say we use the EN2340QI to transform the 10V input down to 5V and then we use the EN6360 to transform the 5V input down to 1.1V. The EN2340QI can achieve an efficiency of 93% and the EN63A0 an efficiency of 90%. If you can afford the space, is this a possibility? Is the output ripple of the second converter still lower than the 30mV than required? Or do you have any other parts or recommendations to improve the efficiency? also with light load conditions? With kind regards, Andre Dekker1 Reply
I'm not certain that it will improve overall efficiency, you can check that out, but yes you can certainly step down from your battery voltage to 5V, for example using TI's TPS62133, then step down to 1.1V from there. I recommend TI's Webench for designing a switcher, very convenient.
