16 years agoEditing the Block diagram of a schematic
If I have a schematic and I goto File-> Create/Update-> Create symbol files for current file, it creates a block diagram of the schematic. The problem is that the position of the input/output p...
16 years ago]I usually don't find the RTL view very user readable ;) I mostly use it to check that the synthesizer understood the code the way I wanted it to.
As for the graphical input, it is true that it looks easier when you start making FPGA designs. But after a while, you have some needs that are difficult to cover with bdfs:- Big projects: in my company we have some old complex projects done entirely in bdf. It spawns on a couple dozen pages, filled with gates, registers, comparators, arithmetic operators... It is very difficult to follow the original author's intentions
- Comments: it is difficult to comment a graphical file. For a complex project, lack of good comments is asking for trouble on the long run
- Maintainability: when adding a new functionality, you may have to move half of the components around the screen to make space for your new components. Also as you discovered, adding/removing ports can also take a while
- Reusability: with a bit of experience, you can write generic HDL code that uses configuration parameters, and that can be reused in several projects and cope with different needs/situations. Big time saver in the long run
- Source control: I never tried to use CVS/SVN with bdl files, but text files are always easier to put under source control.
