Editing the Block diagram of a schematic
If I have a schematic and I goto File-> Create/Update-> Create symbol files for current file, it creates a block diagram of the schematic.
The problem is that the position of the input/output pins may not be like I want them to be. But of course I can just edit the block diagram and move the input/output pins to where ever I want. The problem comes where I have a very huge circuit with a lot of input/output pins, I make a block diagram and spend some time editing it. Then I find out that the circuit needs just a Bit changing and than I have to do File-> Create/Update-> Create symbol files for current file; again. This totally puts the pins in the same old way in the block diagram (which is supposed to get update only but gets rewritten) and than I have to do edit again on the block diagram! How can I prevent Altera from changing the whole shape of the Block diagram and just perhaps add/remove a pin to/from it. So that I don't have to spend a long time fixing the position of all the pins in the block diagram?7 Replies
]I usually don't find the RTL view very user readable ;) I mostly use it to check that the synthesizer understood the code the way I wanted it to.
As for the graphical input, it is true that it looks easier when you start making FPGA designs. But after a while, you have some needs that are difficult to cover with bdfs:- Big projects: in my company we have some old complex projects done entirely in bdf. It spawns on a couple dozen pages, filled with gates, registers, comparators, arithmetic operators... It is very difficult to follow the original author's intentions
- Comments: it is difficult to comment a graphical file. For a complex project, lack of good comments is asking for trouble on the long run
- Maintainability: when adding a new functionality, you may have to move half of the components around the screen to make space for your new components. Also as you discovered, adding/removing ports can also take a while
- Reusability: with a bit of experience, you can write generic HDL code that uses configuration parameters, and that can be reused in several projects and cope with different needs/situations. Big time saver in the long run
- Source control: I never tried to use CVS/SVN with bdl files, but text files are always easier to put under source control.
Yes that's true, I never think to use it for that.
Jérôme, the RTL Viewer provides a graphical look at your system and provides a sort of compromise between HDL and schematics.
for simulation in ModelSim you can still convert the BDF to an HDL file by going to File => Create/Update => HDL for Current File.
learning HDL is still probably a good long term goal. things like generate statements can make instantiating a single component dozens of times just a few lines of code. :) - Altera_Forum
For joe306, you can have a project with bdf and simulate it with a third party simulator, this is not a problem. In Quartus you open the bdf file and then you click on File-> Create/Update -> Create HDL Design File for Current File And Quartus will create a HDL file (with the component and port map) that you can use with ModelSim. This is what I do for my project. Else, I find quite strange that bdf files are not very use, because it is far more easier to watch a system in a graphical way. Jérôme - Altera_Forum
Hello, I experience the same problem and I don't think there is a solution. I believe that not many people use .bdf files. I've posted questions regarding .bdf files and symbols and not many people respond. I can see that within a year or so I'll not be using .bdf in my designs because the Quartus simulator will no longer be available and you will need to use a third party simulator such as ModelSim which doesn't support .bdf files.
Just my two cents. joe - Altera_Forum
I don't think you can do that. The best way to handle that case IMHO is to simply not use the graphical tools and connect your blocks using HDL.
