12 years agoDynamic clock selection in Cyclone 4E
Does anybody know if it is possible to dynamically switch between 4 clocks of 1 PLL in a Cyclone IV E device? I tried several options, cascading clock control blocks, used 2 PLLs, each generating ...
12 years agoAs you found out, you're not going to be able to get there with the clock control blocks ("They don't work that way.")
In one of my systems, I was able to use the HDL clock mux from the Altera cookbook successfully. There is also this relevant thread topic: http://www.alteraforum.com/forum/showthread.php?t=2388 Good luck.
