9 years agodwc2 ffb40000.usb Overcurrent change detected
I get the message when writing to OTG/USB (de0-nano-soc)
dwc2 ffb40000.usb Not connected dwc2 ffb40000.usb Overcurrent change detected -- then my attached storage is gone till the next reboot - while investigating i have removed the supply to the USB device & am powering externally therefore there should be NO over current (current to external device is <100ma so should still not have an issue ) there are no devices being powered off the board - only load is the fpga & support circuitry on the board (running both processors {linux kernel 4.4.0) , one instance of NIOSII & one of msgdma) works fine when writing to local SDcard... next guess is a heating issue - as it seems to function while cold but within 5-10min it fails as above .. .. any hints ? should i be looking at heatsinks & fans (uuggh) ?1 Reply
sigh ... switch mode power supply issue ..
added some large capacitors / & everything is fine .,.
