14 years agoDuty-cycle of PLL's input clock
Hi I attempted to generate a 20MHz 50% duty-cycle clock from a 20MHz 25% duty-cycle clock by the PLL of FPGA. However, the result is a 40MHz 50% duty-cycle clock. The PLL parameters are : ...
14 years agoThank you!
Now Problem solved. Just change the two FPGAs' clk pin I/O standard "LVDS" to "3.3-V LVTTL" Could anyone explain it? Thanks
