14 years agoDUAL_PURPOSE_CLOCK_PIN_DELAY issue on Cyclone IV E
Hi All,
I am currently implementing my own mobile DDR-SDRAM controller and I am encountering some issue. Indeed, during a read from the external memory, I want to delay the data strobe (DQS) to be able to correctly capture the data (DQ). In order to do this, I use the following assignment to add a delay on DQS line: set_instance_assignment -name DUAL_PURPOSE_CLOCK_PIN_DELAY 8 -to lpddr_dqs The problem I have is that Quartus does not report any delay at all. But it doesn't ignore the constraint either. I was expecting to see some delay in the" fitter/Resource Section/Delay Chain Summary" but all the delays seem to be fixed at 0 ns. Does someone know where we can check the actual value of this delay? Or is there a problem with my way of doing things? Thanks a lot in advance!No RepliesBe the first to reply
