14 years agoDual port RAM synchronisation
Sorry if this post is in the wrong group. We have a system where a NIOS application communicates with a PC-104 style board via dual port RAM. Some of our tests indicate that if the NIOS is...
14 years ago --- Quote Start --- Correct. Is it (I believe) a non-bus master PLX chip. --- Quote End --- Then you are in luck. The PLX chips normally have doorbell registers/interrupts for implemented an interlocked protocol. See page 7: http://www.ovro.caltech.edu/~dwh/correlator/pdf/cobra_driver.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/cobra_driver.pdf) That interlock acts as a mutex for access to the shared resource. The key to understanding how this sort of protocol works, is to think of the protocol handshake in terms of transmitter-empty and receiver-ready interrupts. The "character" being protected by this protocol can be multiple characters. In this example, the character is stored in a mailbox in the PLX chip. In the real driver, multiple mutexes are used, and protect different regions in shared SDRAM. Cheers, Dave
