16 years agoDual port Fifo with 400MHz
Hi, I never worked with FPGAs until now :confused:. I need a dual port FIFO with the following specs: At the input side I want to gather blocks of data from a AD system with 400MHz clock r...
16 years ago:rolleyes: Please do not laugh at me, but I would very much like to get a FPGA in a QFP housing for the beginning (avoiding BGA - this would simplify the PCB soldering considerably).
I looked through the Cyclone III documentation and found the EP3C40Q240C8 in the P240 housing with 128 IOs and 126 M9K memory blocks (=about 126kByte, well enough for me). Summing up the pins, I reach 72 for the standard app (28bit * 2 for LVDS on the input side= 56, and 16 bit on the output side (no LVDS)), so I have 56 free pins for control and clock, this definitely should be enough. Is this calculation approximately ok and this Chip would be ok for me? (unfortunately P240 housing only available in speed grade C8 - but this specifies 238 MHz for the memory, which is I hope sufficiently above my needed 200MHz). :confused: (I feel especially unsure concerning your remark of the necessary bus splitting: Is it possible to do this in the FPGA array, or is it necessary feed the 28 input bits two differents LVDS inputs each - in this case of course I could bury my QFP dreaming, as then I would additional 56 pins alone for the bus splitting).
