9 years agoDual-port access avalon memory simulation problem
Hello, I have created an Avalon dual access on-chip memory in Qsys and tried to simulate it, with success, everything worked just fine. Then I put this module in a VHDL component, and did nothi...
9 years agoI think I found a possible cause for the problem. I am using Modelsim Starter Edition, my surrounding code is in VHDL, while the code generated by Qsys is in verilog. The Starter Edition for what I´ve seen does not support mixed-language simulation, so this may well be at the root of the problem. Does anyone know whether it is possible to generate the tempcalc_onchip_memory2.0.v and the functions used in it in VDHL instead of verilog? Choosing to create HDL design files for synthesis does not change this generated file.
UPDATE: I have recreated my surrounding modules in verilog(there are some decent VHDL->verilog converters online, I chose vhd2vl), and run the simulation with those, generating the whole qsys module in verilog too. The simulation works without a problem now.
