MJone6
8 years agoDual Configuration IP does not trigger reconfiguration in MAX 10
I have a design using 10M16SAU169I7G, with an instance of the remote_configuration IP. The nCONFIG pin is enabled like the NIOS example, and using some external pin logic, I can select and configure ...
MJone6
8 years agoI moved the extra line to the qsf file and it still works.
UG-M10CONFIG doc says on page 2-9: “By default, the remote system upgrade features is enabled in all MAX 10 devices when you select dual compressed image internal configuration mode.
I believe it is a Quartus bug that this extra line enabling internal nCONFIG is not put into the qsf file when you select dual mode.
Mike
