MJone6
8 years agoDual Configuration IP does not trigger reconfiguration in MAX 10
I have a design using 10M16SAU169I7G, with an instance of the remote_configuration IP. The nCONFIG pin is enabled like the NIOS example, and using some external pin logic, I can select and configure ...
MJone6
8 years agoI found the problem. In the qdf file is this:
set_global_assignment -name ENABLE_NCONFIG_FROM_CORE On
I did not know about this file, so it was missed.
Where in the Quartus GUI do you set this?
Mike
