MJone6
8 years agoDual Configuration IP does not trigger reconfiguration in MAX 10
I have a design using 10M16SAU169I7G, with an instance of the remote_configuration IP. The nCONFIG pin is enabled like the NIOS example, and using some external pin logic, I can select and configure ...
MJone6
8 years agoI'll add to this that I put a scope on STATUS/ and CONF-DONE, and when CONFIG/ is asserted at the pin, I see them go low and high, and when offset 0 bit one is used, these pins do not change state. I did this to ensure there was not a reconfiguration/load of the image combined with a failure. I internal method just fails to trigger.
