Amir3
3 years ago"Dual Configuration" IP-Core (MAX 10) - Timing issue
Hey, I'm using a 10M16SAU169I7G with "Dual Configuration" IP-Core. There is 1 Clock in the design and its rate is ~14[MHz]. Timing analysis process: At first, I got this warning: After se...
RichardT_altera
3 years agoThis might be related to the KDB below:
Could you try to use the timing constraint stated in the KDB so that the RU_CLK runs at half the rate of the input clock.
https://www.intel.com/content/www/us/en/support/programmable/articles/000080607.html
FYI, the MAX 10 FPGA Configuration User Guide states that the Altera Dual Configuration IP generates RU_CLK that runs at half the rate of the input clock.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
