Amir3
3 years ago"Dual Configuration" IP-Core (MAX 10) - Timing issue
Hey, I'm using a 10M16SAU169I7G with "Dual Configuration" IP-Core. There is 1 Clock in the design and its rate is ~14[MHz]. Timing analysis process: At first, I got this warning: After se...
sstrell
3 years agoDid you set the clock frequency appropriately in the parameter settings for the IP? Can you show your .sdc?
And this single clock is the only clock in your entire design? Can you show the details of the failing timing path from the timing analyzer?
