jozephka99's avatar
jozephka99
4 years ago
Dual Boot (Configuration) IP registers cannot read
Spoiler
I use altera_dual_boot (Dual Configuration) IP core without Nios II. I use the IP core for RSU implement. I can write the writable registers with addresses [0,1] (Trigger reconfig and config selection registers). But I cannot read the read only registers such as addresses [3,7] (Busy state and config selection info registers). When I try the read them, I get 0. I though they are really be 0 but I change the config sel reg and read after that, it still give me 0. I know I successfully change the config sel because I can reconfig from the selected CFM.
By the way they are not any documentation about how can we read or write the data to this regs. IP core's document (ug_m10_config) just tells the regs addresses. In the platform designer, I export the dual boot IP pin to control it over VHDL. The exported pins are {address, read, write, read_address, write_address}. I assume the read and write signals are for enabling these operations.
In the VHDL code, I use these signals like:
Component definition:
component pdesigner is
port(
clk_clk: in  std_logic:= 'X'; -- clk
reset_reset_n: in  std_logic:= 'X'; -- reset_n
dual_boot_avalon_address: in  std_logic_vector(2 downto 0):= (others => 'X'); 	-- address
dual_boot_avalon_read: in  std_logic:= 'X'; -- read
dual_boot_avalon_writedata: in  std_logic_vector(31 downto 0):= (others => 'X'); 	-- writedata
dual_boot_avalon_write: in  std_logic:= 'X'; -- write
dual_boot_avalon_readdata: out std_logic_vector(31 downto 0)	-- readdata
end component;
Port mapping:
rsu_block : component pdesigner
port map (
clk_clk                    => clk,
reset_reset_n              => reset,
dual_boot_avalon_address   => db_avalon_address,
dual_boot_avalon_read      => db_avalon_read,
dual_boot_avalon_writedata => db_avalon_writedata,
dual_boot_avalon_write     => db_avalon_write,
dual_boot_avalon_readdata  => db_avalon_readdata
RTL:
cnt <= cnt + 1;
if(cnt = 0) then
db_avalon_address 	<= "011";	-- rsu busy reg
db_avalon_write 	<= '0';
db_avalon_read 		<= '1';
elsif(cnt = 5) then
db_avalon_read 		<= '0';
LED(0)              <= db_avalon_readdata(0); -- rest of them is reserved
elsif(cnt = 10) then
db_avalon_address 	<= "001";
db_avalon_writedata(0) 	<= '1';	-- set config_sel_overwrite
db_avalon_writedata(1)	<= boot_cfm_sel;	-- set config_sel
db_avalon_writedata(31 downto 2) <= (others => '0');	-- reserved
db_avalon_write 	<= '1';
elsif(cnt = 15) then
db_avalon_address 	<= "111";	-- config sel input reg
elsif(cnt = 20) then
LED(1)              <= db_avalon_readdata(0);
elsif(cnt = 25) then
db_avalon_address 	<= "000"; -- trigger reconfig
db_avalon_writedata <= x"00000001";	-- hold nconfig min 250ns, 4 cycle at 12 MHz
else
end if;
So with this code, I can write and reconfig but cannot read the registers. Any help will be appreciated.
  • sstrell's avatar
    sstrell
    The read signal is active high. Why are you setting db_avalon_read to 0 when you're trying to do a read? The read signal must be held with the address to perform a read.
    I'm presuming this is a clocked process for the cnt signal.
    • jozephka99's avatar
      jozephka99
      Yes this is clocked process, I don't want to bother you with legwork. I'm setting the db_avalon_read high for 5 cycles then I clear it. My measurement show me that 3 cycles are enough for read / write. I changed my code a little bit and I can read the busy signal but still no data at config sel reg. Here is my edited code:
      if(cnt = 0) then
         db_avalon_writedata(1)<= boot_cfm_sel;	-- set config_sel
         cnt <= cnt + 1;
      elsif(cnt = 3) then	-- write operation needs 3 cycle
         cnt <= cnt + 1;
      elsif(cnt = 4) then
         db_avalon_address 	<= "011";	-- busy reg
         cnt <= cnt + 1;
      elsif(cnt = 5) then	-- read operation needs 1 cycle
         cnt <= cnt + 1;
      elsif(cnt = 6) then	-- read data came in 2th cycle
         if(db_avalon_readdata /= x"00000000") then
      	cnt <= 4;
         else
      	cnt <= cnt + 1;
         end if;
      elsif(cnt = 20000000) then
         cnt <= cnt + 1;
      else	-- wait for FPGA trig reconfig
         cnt <= cnt + 1;
      end if;
      • sstrell's avatar
        sstrell
        I don't see you accessing address 7 at all in this revised code.
