11 years agoDSP Dev Kit PLL Output Pins Question
I have the DSP development kit that has the Cyclone 2. It has SSRAM and some DDR2 memory. I am testing the SSRAM. I have it working at 100 MHz. In the top level code I am using a PLL to generate 3 cl...
11 years agoThanks.
It took a day to get it working at 100 MHz. The trick was to get the correct Cypress data sheet and follow the timing diagrams. Using SignalTap my code writes and reads all locations. You are correct because if jitter was a problem it wouldn't work. Won't worry about it I'll check Pin Planner. Swimteam.
