14 years agoDSP Builder with Cyclone II (EP2C35F672C6N)
Hi, I have one question, Is it Cyclone II (EP2C35F672C6N) device support DSP Builder?:confused: Thank you
14 years agoDSP Builder has direct support for some development kits. What this means is that it has been preprogrammed with the pin assignments for the LEDs, buttons, etc...
If DSP Builder doesn't have direct support for a particular development kit, you can still program the FPGA in it using DSP Builder, but you will have to add your own pin assignments to access the board features. If the Altera website doesn't mention the kit you have, then you will have to provide your own assignments (using the data sheets as a reference).
