8 years agoDriving Ladder DAC
Hi, Im trying to drive a resistor ladder DAC from my DE-1 SOC board, despite of my DAC being very accurate im getting somewhat shotty results. The setup is relatively simple driving the resis...
8 years agoWhat should the waveform look like?
Do you have passive pullups and/or bus hold function enabled on those I/Os? Can you set all the outputs to Z, and then only drive one bit (ie, the msb) between Z and 1 (or Z and 0) and capture the waveform?
