8 years agoDriving Ladder DAC
Hi, Im trying to drive a resistor ladder DAC from my DE-1 SOC board, despite of my DAC being very accurate im getting somewhat shotty results. The setup is relatively simple driving the resis...
8 years agoUpon closer inspection I must have botched something using a case statement to drive my logic. So things might not be so gruesome as they appear in the 1st picture :P
EDIT: Nope, its bad, "this" bad then. https://alteraforum.com/forum/attachment.php?attachmentid=15341&stc=1 Im scratching my head as to what can be causing this issue, does this mean the current gets sunk into ground and only the spikes shows up on the image? Should it? Should I be wanting a higher impedance from it?
