12 years agoDriver output impedance in Arria II GX for 3.3V LVCMOS / LVTTL I/O standard
I understand that ARRIA II GX does NOT support output serie resistor OCT (with or without calibration) for 3.3V I/O banks. Nevertheless, I have to adapt the impedance of the line but I couldn't find anywhere the min/max values of the driver output impedance and pick the correct value for the external serie resistor, anyone can help? Thank you in advance.1 Reply
LVTTL has programmable drive strength which can be used to adjust the output impedance. There's no data sheet specification, but you can derive the expectable impedance range from the device ibis files.
