14 years ago
Driver Crash Problem
I am running Windows XP and I am using Jungo WinDriver to access the Altera PCIe card. Whenever I try to run my software, I get a DLL not found error.
Tracing through the software, I found the problem to be when it tries to initialize the card at software startup.
I used Jungo's Driver Wizard to create altera_lib.c
DWORD ALTERA_CountCards (DWORD dwVendorID, DWORD dwDeviceID)
WD_VERSION ver;
WD_PCI_SCAN_CARDS pciScan;
HANDLE hWD = INVALID_HANDLE_VALUE;
DWORD dwStatus;
WD_LICENSE lic;
ALTERA_ErrorString[0] = '\0';
hWD = WD_Open(); <--crash at this line
// check if handle valid & version OK
if (hWD==INVALID_HANDLE_VALUE)
sprintf( ALTERA_ErrorString, "Failed opening " WD_PROD_NAME " device\n");
return 0;
else
BZERO(lic);
strcpy(lic.cLicense,ALTERA_DEFAULT_LICENSE_STRING);
dwStatus = WD_License(hWD,&lic);
if (WD_STATUS_SUCCESS !=dwStatus) {
sprintf(ALTERA_ErrorString,"Could not register license\n");
return 0;
I took the function above and commented out the entire body and progressively enabled each line until I got to the line indicated above. This calls into windrv.h and the entire program crashs.
The card itself is working. I have some code in MATLAB that test writes to a register and that is working properly.
What is causing the crash and how do I resolve it?
Jason
