8 years agodrive the input pins during the power-up/down sequence
Hi, Can I set the output of the external, peripheral chips(connected to the FPGA Arria10) in the in the VCCIO-GND voltage range during the power-up/down sequence for LVDS Banks? Can I set the ...
8 years agothe table 124 shows:
1. 3VIO banks - Tristate. Is it necessary to install this mode(Tristate) on the outputs of the external, peripheral chips without pull-up or pull-down resistors? Is it necessary to install this mode(Tristate) on the outputs of the external, peripheral chips if the VCCIO=1.8V? 2. LVDS I/O banks - Drive to GND or Drive to VCCIO. Why can't these contacts be drived in the VCCIO-GND voltage range?
