19 years agoDRAM and SRAM with Cyclone III
Hello all, I have some general questions regarding the use of DRAM and SRAM memories with Cyclone III devices. 1) DRAM memory Do I need to connect the DRAM memory chip directly to the de...
19 years ago --- Quote Start --- Thank you for your quick help. I continue to investigate to check if can use any I/Os or if I must use the dedicated pins. If someone has already designed a digital board with Cyclone (II or III whatever) using a DRAM device, please let me know. --- Quote End --- Hello. I did. I connected two DDR SDRAM to CYCLONE III (EP3C25) and everything is working. I don't use altmemphy because I need burst length equal to 8 and altmemphy doesn't support it.
