8 years agoDQS Input and Output Timing Constraints
Greetings, I have a DDR controller which has a bidirectional DQS (data strobe) signal. In read states, the DDR device is driving DQS, as well as some data bits which have timing relationship to...
8 years agoAs an experiment, I removed all statements related to input constraints, and just focused on the output constraints:
create_generated_clock -name CLK_ddr_ldqs_OUTPUT -source { inst5|altpll_component|auto_generated|pll1|clk }
set CLK_ddr_ldqs_n_OUTL CLK_ddr_ldqs_OUTPUT;
set_output_delay -clock $CLK_ddr_ldqs_n_OUTL $tDS -max
set_output_delay -clock $CLK_ddr_ldqs_n_OUTL -$tDH -min
set_output_delay -clock $CLK_ddr_ldqs_n_OUTL $tDS -max -clock_fall -add_delay
set_output_delay -clock $CLK_ddr_ldqs_n_OUTL -$tDH -min -clock_fall -add_delay Now, the timequest looks as I'd expect (attached). So obviously the SDC needs this "create_generated_clock" statement. To prevent the compiler from complaining, I had to remove the "create_clock" statement from the input portion. Is there a way to keep both? sstrell mentioned not having derive_pll_clocks? What would my constraints need to look like?
