PascalPolygon
5 years agoDP to MIPI
Hello guys,
Does intel offer an FPGA that supports DP RX and MIPI DSI TX?
If yes, does the FPGA have a D-PHY bank or is it implementing D-PHY through external resistors?
Lastly, are there any ...
Deshi_Intel
5 years agoHI,
Unfortunately Intel doesn't has DP to MIPI conversion IP. Both IP is sold as individual standalone IP only.
For DP IP :
- Intel does offer DP IP solution. You can checkout below DP user guide for more info
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_displayport.pdf
For MIPI IP :
- Intel doesn't offer MIPI IP solution in house. We are relying on 3rd party design house to offer MIPI IP hence I am not sure about the design implementation detail
- I found out 2 design house that provide MIPI solution. Feel free to engage with them
- https://www.mikroprojekt.hr/products/system-solution/mipi-cameras-displays/mipi-dsi-solution
- https://www.rambus.com/interface-ip/controllers/mipi-controllers/
dlim
PascalPolygon
5 years agoHello Deshi,
Thanks for the reply. I see that the MAX 10 FPGA is not included in the supported devices for the DP IP. Is there anyway to make the DP IP work on the MAX 10 FPGA?
Pascal.
