14 years agoDownloading ELF Process failed of Project
Good night everybody , I have problem of QuartusII 10.1sp1 . My user chip is CycloneII EP2C35FC8 , when my sopc builder use Pll、SDRAM、FLASH、MCU、JTAG , I can run...
14 years agoDear Daixiwen
About phase shifts on the clock , I reference the de2_115_web_server of QuartusII config , so I use the enet_rx_clk_pll component. And my Internet chip is use 88e1111 , and my QuartusII Core is copy example of web_server_de2_115 , but my core is use CyclonII . at my hardware indicate led have rx、duplex、link1000 . But link1000 should not be bright...it is abnormal... should be bright is link100... (Refer DE2-115 Board , it bright RX、DUPLEX、LINk100、TX(have cable)) TSE driver ? your mean is QuartusII on the setting → files and add altera Built-in ip code ? I have do of add that . (altera → triple_speed_ethernet → lib → ip code) I think...maybe problem is from my QuartusII Project...or hardware problem just I think ... and I will keep try : )
