14 years agoDownloading ELF Process failed of Project
Good night everybody , I have problem of QuartusII 10.1sp1 . My user chip is CycloneII EP2C35FC8 , when my sopc builder use Pll、SDRAM、FLASH、MCU、JTAG , I can run...
14 years agoDear Daixiwen
so I need return "SOPC Builder" and set pll of three output : system_clk(100Mhz) sdram_clk(100Mhz -65deg) onchip_clk(100Mhz -130deg) <-- for on-chip(Enth ─ DMA use) clk your mean is this ? And I still don't understand your mean of defin the i/o timing ... can you explanation this mean of defin : ) ?
