14 years agoDownloading ELF Process failed of Project
Good night everybody , I have problem of QuartusII 10.1sp1 . My user chip is CycloneII EP2C35FC8 , when my sopc builder use Pll、SDRAM、FLASH、MCU、JTAG , I can run...
14 years agoYes you need to define your timing requirements.
For the on-chip memory the only thing you need to define is your clock input frequency and use the derive_pll_clocks command. Timequest will determine all the internal timing from this. For the SDRAM and Flash you need to define the I/O timing.
