14 years agoDownloading ELF Process failed of Project
Good night everybody , I have problem of QuartusII 10.1sp1 . My user chip is CycloneII EP2C35FC8 , when my sopc builder use Pll、SDRAM、FLASH、MCU、JTAG , I can run...
14 years agoDear Daixiwen
Thanks your answer , I found my sopc builder , haven't System id component , so I add this component , moreover move the top and Auto-Assign Base Addres、IRQS . when I finish compilation , I programmer project for my board . (still keep open the programmer window) Then I use Eclipse and creat Application and BSP from Template . When I run as web_server_socket(rgmii) , the message still tell me downloading elf process failed
but appear the message befor , have other message . The message tell me assertion "m_state==state_debug" failed : file
"nios2oci.cpp",line 158
using cable "usb-blaster [usb-0]", device 1 , instance 0x00
pausing target processor : not responding .
resetting and trying again : /cygdrive/c/altera/10.1sp1
/nios2eds/bin/nios2-download : line 601: 2380 hangup.
