Does CURRENT_STRENGTH_NEW limit current?
- 2 years ago
current strength specification has nothing to do with limiting output current to a certain value. The mA value defines the maximum load current that keeps output voltage drop within the logic level specification of a certain IO standard. Maximal output current, e.g. into shorted output is much higher and exceeds in most cases FPGA maximum rating so that the output driver may be damaged.See for example the output characteristic of Cyclone 10 LP CMOS 3V IO standard with 4 mA current strength according to IBIS files.
The only IO standard that limits output current to a safe value is LVDS 2.5 V. HSMC breakout adapter is obviously designed to use this standard.
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
