xytech
Contributor
7 years agoDoes A10 GX device's banks need individual clocks input from the dedicated CLK pins for DDR4 ?
Hi, there, we use A10 GX(10AX057H3F34E2SG) for one DDR4 SO-DIMM mempry card. bit width 64, and three FPGA banks are used. In our previous experience for DDR3, these banks do not necessarily need t...
- 7 years ago
Hi xytech,
Thank you so much for the details clarification. It really helps to understand the issue better.
Yes, your understanding is correct. Since the current clock source is not a dedicated to the PLL that you want to use with your DDR4, then you need to add another clock device to feed the ref_clk. Please note that using additional clock will slightly give effect to the clock jitter and timing margin which also mentioned in the handbook.
NAli1
NurAida_A_Intel
7 years agoHi xytech,
This platform is open for community. Anyone who have the answer/solution to the issue are welcome to answer the thread 😊
