Does A10 GX device's banks need individual clocks input from the dedicated CLK pins for DDR4 ?
- 7 years ago
Hi xytech,
Thank you so much for the details clarification. It really helps to understand the issue better.
Yes, your understanding is correct. Since the current clock source is not a dedicated to the PLL that you want to use with your DDR4, then you need to add another clock device to feed the ref_clk. Please note that using additional clock will slightly give effect to the clock jitter and timing margin which also mentioned in the handbook.
NAli1
Hi xytech,
You must use external dedicated clock inputs for the PLL ref clock driving the clock tree.
External memory interfaces that span multiple banks use the PLL in each bank. The relatively short span of the PHY clock trees results in low jitter and low duty-cycle distortion, maximizing the data valid window.
If you open the DDR4 IP in the IP Parameter Editor, under the "General" tab the recommended PLL ref clock jitter is 10ps. This may change depending on what Memory clock frequency and PLL ref clock frequency you choose, but 10ps (or less) is the generally recommended value.
For more detail, you can refer to "Chapter 2.1.8 PLL Reference Clock Networks" (page 22) of this EMIF handbook --> https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20115.pdf
Hope this helps.
NAli1
- xytech7 years ago
Contributor
Hi, NAli1, thanks for answer. let me be more specific. Now we only have one differantial Main_CLK connect to FPGA from Bank 2J's dedicated PLL input pins (AP24, AN24), the clock jitter before FPGA is 180fs. However, DDR4 uses 3 banks : 3D, 3E, 3F, with all command and adress pins located in bank 3E.
Quote UG-20115 page 225-226 section 6.3.2.2 "For the clock source, use the clock input pin specifically dedicated to the PLL that you want to use with your external memory interface. The input and output pins are only fully compensated when you use the dedicated PLL clock input pin. If the clock source for the PLL is not a dedicated clock input pin for the dedicated PLL, you would need an additional clock network to connect the clock source to the PLL block. Using additional clock network may increase clock jitter and degrade the timing margin", and section 2.1.8 "If you plan to use an on-board oscillator, you must ensure that its frequency matches the PLL reference clock frequency that you select from the displayed list" .
So, from your infoamtion, We should add another clock device such as clock IC or Oscillators or Crystals on board and connect its outputs into decicated PLL inputs pins of either one of Bank 3D/3E/3F.If I use Bank 3E, the pins should be G5/G6 or F5/F6. Also, the jitter and frequency should be properly selected . And we CAN NOT use the exsisting MAIN_CLK + Global clock NETWORK to feed ref_clk input of DDR4 controller as pic below (figure 11 of UG-20115). Is my understanding correct?
Thank you very much!
