14 years agoDMA transfer from FIFO to DDR2
I am using Altera DMA controller to tranfer data from the FIFO to the DDR2 controller.But i want to start the DMA request while the FIFO is empty also i need to make the DMA wait while the FIFO is empty .So the transfer is done when the FIFO is empty. the following is the NIOSII code i use for dma transfer : --- Quote Start --- void use_dma_st_mem(void* src,void* dest,alt_u32 length) { int rc; alt_dma_txchan txchan; alt_dma_rxchan rxchan; printf("start use_dma_st_mem\n"); /* Create the transmit channel */ if ((txchan = alt_dma_txchan_open("/dev/dma_0")) == NULL) { printf ("Failed to open transmit channel\n"); exit (1); } /* Create the receive channel */ if ((rxchan = alt_dma_rxchan_open("/dev/dma_0")) == NULL) { printf ("Failed to open receive channel\n"); exit (1); } /// Streaming from Trasnmit channel if ((rc = alt_dma_txchan_ioctl (txchan,ALT_DMA_TX_STREAM_ON ,src)) < 0) { printf ("Failed to post alt_dma_txchan_ioctl = %i\n", rc); exit (1); } /// configuring receiver channel if ((rc = alt_dma_rxchan_ioctl (rxchan,ALT_DMA_RX_ONLY_ON ,dest)) < 0) { printf ("Failed to post alt_dma_txchan_ioctl = %i\n", rc); exit (1); } /* Post the transmit request */ if ((rc = alt_dma_txchan_send (txchan, src, length, NULL, NULL)) < 0) { printf ("Failed to post transmit request, reason = %i\n", rc); exit (1); } /* Post the receive request */ if ((rc = alt_dma_rxchan_prepare (rxchan, dest, length, done_rx, NULL)) < 0) { printf ("Failed to post read request, reason = %i\n", rc); exit (1); } /* wait for transfer to complete */ printf ("waiting tx_done!\n"); while (!done_rx); printf ("Transfer successful!\n"); return 0; } --- Quote End ---No RepliesBe the first to reply
