17 years agoDMA reading multiple PIOs
Hi, My system contains a total of twenty two (22) 16-bit I/O ports (Altera PIOs) that are used to read external (10 bit) ADCs. My system is running at 85MHz and my maximum sample rate should b...
17 years agoJake,
No, I have never used this tool. It has amazed me that I have this system working with knowing so little. It is not until you start tweeking that you get into the tools you should have used up front. Thanks for pointing me in this direction. Fred
