Jeffrey
1 month agoDK-DEV-AGI027RBES CXL Type-3 example remains in reset and is not detected by host
Hi, I have several Agilex 7 FPGA I-Series Development Kits with serial numbers 8100035 and 8020138. My goal is to run the boards as CXL Type-3 devices and verify that they can be enumerated by the h...
Jeffrey
1 month agoRongY_altera thanks for your reply, the CXL type3(8020138-RBES-ES2) now works, the solution is using Quartus 23.3 to compile the example design. I think 8100035-R1BES-ES1 board should also require specific version of Quartus to compile, do you which version?
RongY_altera
Contributor
1 month agoThanks for the feedback. For the R1BES, you can also start with Q23.3.
You can generate an example design from Q24.3.1 too. If I remember correctly, the generated design should work. Since we are in the middle of a lab move, I’m not able to confirm this with my test records right now.
Rong
