Jeffrey
1 month agoDK-DEV-AGI027RBES CXL Type-3 example remains in reset and is not detected by host
Hi, I have several Agilex 7 FPGA I-Series Development Kits with serial numbers 8100035 and 8020138. My goal is to run the boards as CXL Type-3 devices and verify that they can be enumerated by the h...
Jeffrey
1 month agoHi Rong, I created a pof with CXL example design and refclk4 based led heartbeat. And the Led was blinking with this pof, which means the pof was load successfully from flash. But the CXL IP reset seems not release and always low. Will the Max10 BMC case this issue?
