DK-DEV-5CSXC6N-B - Require assistance with technical aspects.
Hello Kian,
I understand that your primary focus is on providing sales support; however, we are in urgent need of technical assistance at the moment, and I hope you understand. I would like to ask a few questions regarding the FPGA code we’re working on. Currently, we are using U-Boot as the boot loader, along with .jic and .rbf for programming. My specific questions are
Our FPGA code for Ethernet is connected to the HPS with an HPS wrapper, whereas in the Intel Eval Kit, the Tri-Speed MAC soft core is used. Is there any advantage to using the Tri-Speed MAC in this case?
Regarding the low-speed results we are seeing, what possible code improvements would you recommend? If feasible, we would also appreciate the opportunity to discuss this further with you.
Hello Kian,
I’d like to kindly follow up since it has been a few days without a response. We have identified a possible cause of the issue—using ethtool, we observed that the link is running at 10 Mbps half-duplex, even though we intended it to be 100 Mbps full-duplex.
May I ask if Intel could provide guidance on this, particularly regarding the software side and any recommended FPGA driver configurations that might help resolve the issue?
