Rk_Athram
5 years agoDisplayPort IP generated design example supports ATX PLL ?
ATX PLL in the DisplayPort IP generated design example
I have gone through the UG :Intel® Arria® 10 DisplayPort IP Core Design Example User Guide UG-20075...
Deshi_Intel
5 years agoHi,
Thanks for the clarification. I see your point now but this is not the recommended design practice.
- It's recommended to always recalibration either the PLL or the transceiver channel depends you are modify which block to change speed
- So that you get the most accurate internal analog setting tuned for your application current voltage and temperature condition
The pre-calibration feature in the DisplayPort example design is forced to be done to shorten the Displayport link boot time time. This is one outlier case here.
For your case, I suggest you to follow the recalibration process after changing speed as per guideline in Transceiver PHY user guide doc.
dlim
