Rk_Athram
5 years agoDisplayPort IP generated design example supports ATX PLL ?
ATX PLL in the DisplayPort IP generated design example
I have gone through the UG :Intel® Arria® 10 DisplayPort IP Core Design Example User Guide UG-20075...
Deshi_Intel
5 years agoHi,
Oh, I didn't realized you are not using DisplayPort IP and in fact targeting other application.
- Yes, you need ATX PLL if you are running 10G.
- ATX PLL should be able to achieve similar pre-calibration operation as both fPLL and ATX PLL also support reconfiguration profile
Just curious why you need pre-calibration feature ?
- This is unique for DisplayPort protocol only to shorten the Protocol link up time
- For other protocol, normally you can perform transceiver or PLL calibration later once you enter into FPGA user mode.
dlim
Rk_Athram
5 years agoHi,
Our application requirement is to change speed dynamically
for " Multiple Reconfiguration Profiles" i may have to calibrate after changing speed every time.
to save the calibration time i found pre calibration used in DisplayPort is efficient.
Rajesh
