14 years agoDifferent results on hardware compared to simulator
I'm having trouble when I run my code on the actual Cyclone III FPGA. In the simulator it works fine. I have set up state machines to make sure that clock signals to registers are occurring after ple...
14 years agoAs I understood you have used wr, rd as clocks. It does not matter to the compiler if they are regular pulses or not. It will be clocks if used with clock edge assignment.
for bidirectional bus: you don't have to think of bidirectionality. just use two buses, one for each direction until such a point you interface them to actual bidir pins.
