14 years agoDifferent results on hardware compared to simulator
I'm having trouble when I run my code on the actual Cyclone III FPGA. In the simulator it works fine. I have set up state machines to make sure that clock signals to registers are occurring after ple...
14 years ago --- Quote Start --- The most important issue is that a signal is viewed as clock if it is used to edge trigger any register since it will be connected to clk port of flips. The safest thing for a beginner is one clock for all registers. As to tristating inside fpga: you don't need that as it is going to be implemented as muxes and will complicate coding on you. --- Quote End --- Basically I have used the main clock to clock all the registers. But then the data in registers is decoded and enables lower level logic. So, how can I implement a bi-directional bus?
