16 years agoDifference: Quartus Web Edition 9.2 and Quartus Subscription 9.2
Hello, I am using the Quartus Web Edition 9.2, and i wanna start to use Quartus Subscription 9.2 . I know this software is paid, then i wanna know the difference between both. Cause if is the same th...
16 years agoIt depends on device families you will use mainly. Therefore you should check if the Device Support section contains your desired devices.
It is possible to generate programming files (pof, sof, jam, svf) and to program them into devices of course. Another difference is the list of supported operating systems that you can see in the mentioned pdf file.
