FRoth
8 years agoDifference between CML and High Speed Differential IO transceiver I/O standard
We are using A10 transceiver blocks and we use CML and High Speed Differential I/O pin standards interchangeably, since these two standards seem to us to basically describe the same thing. Could you ...
CheepinC_altera
8 years agoHi FRoth,
Yes your understanding is correct. In term of the A10 XCVR, when you use CML and High Speed Differential I/O, the TX and RX specs are actually the same. The only difference is that the A10 TX only support High Speed Differential I/O standard but RX can support High Speed Differential I/O, CML , Differential LVPECL , and LVDS standards.
Chee Pin
