15 years ago
Devide in VHLD
I want to implement this function : A<= B/x"A", when I compile, the Quartus put a notice: "/" used but didn't declare.
When I try with "*" (multiply) or "+" (add), it is ok.
I don't know this error, Please help me.
Thank you very much.
    --- Quote Start ---
    The output is not valid until CNT is 2 anyway, so until then all signals are rubbish.
    --- Quote End ---
    Valid result or not, a registered output can't change arbitrarily. Or the design's timing is completely broken.
    --- Quote Start ---
    Because Modelsim does not support for LPM library. And when I use multiply command directly, the result's not true with the negative number.
    --- Quote End ---
    Last time I used it, all LPM libraries simulated fine in ModelSim. Sorry, I also don't understand about the negative number problems. At least, I wasn't aware of it (since Quartus V2.0).
    --- Quote Start ---
    --- Quote End ---
    Really?
    LPM library took me a lot of time. I use Modelsim plus 5.7d and Quartus 7.2
    Could you help me step by step with it?
    All Quartus specific libraries (LPM and device specific) have been installed during initial ModelSim installation (some ModelSimDE6.1 or 6,2 version). Unlike when simulating Verilog, I don't remember missing library issues with VHDL designs. But I don't have ModelSim installed on my computer now and can't check these problems.
    An additional remark related to your previously posted waveform. You didn't ever mention a device family. The timing could be explained if either belonging to a very slow logic family, or if the synthesis options in effect would allow to move an output register.
    --- Quote Start ---
    You can precompile most libraries in Modelsim.
    Usually altera_modelsim will have these lpm/altera_mf libraries ready from installation.
    Otherwise you can precompile as follows:
    go to modelsim => compile => set library name to lpm => navigate to altera folders that contain 220pack.vhd/220model.vhd. select them and compile.
    --- Quote End ---
    I don't know, why menu compile of my Modelsim software is not active. I can not choose it.
    I add 220pack.vhd/220model.vhd to my project and compile => not ok
    I can not make new library from "a new library and a logical mapping to it" or "a map to an existing library" to folder that contain 220pack.vhd/220model.vhd file.
    This is my video:
    Add 220pack.vhd/220model.vhd to project and compile them: http://www.mediafire.com/?44i1sj5bgnkduty
    Can not make new library: http://www.mediafire.com/?53zp5xyrpd2zdjk
    Can not make new library: http://www.mediafire.com/?krc4l1g5u5uyayj
    Could you check it for me.
    Thank alot
    --- Quote Start ---
    --- Quote End ---
    I'm sorry when i forgot mention a device family.
    I use DE2-70 (Cyclone II) - EP2C70F896C6
    --- Quote Start ---
    --- Quote End ---
    Hi Kaz
    How's about altera_modelsim?
    It's a single software or built-in with quartus software?
    Why I don't see it in my computer?
    Thanks everybody very much. I had already done Modelsim - VHDL. If add 220pack.vhd/220model.vhd in to project and compile it to folder lpm you can work with lpm library in modelsim. Thanks everybody again.
