Mateusz1
4 years agoDevice speed grade
Hello Is there a way to check device speed grade from software? For example something like "Chip ID Intel IP". I cant check speed grade from device package. Can i get it in some way from devic...
- 4 years ago
Nope, not available. The JTAG ID encodes the specific device family and size (number of cells), and number of I/Os (package type, sometimes). Speed grade and temperature grade are not encoded. They are determined after the die is packaged and tested.
You could do that yourself if you wanted to add specific registers for your application that encode such info, but it will not be available on unprogrammed parts direct from the factory.
AqidAyman_Altera
4 years agoHi Mateusz,
Alternative solution, I would recommend you to check on the device overview document for specific family device. From there, you can see the speed grade for the device based on the Device Packaging Ordering Information.
