Device migration about DD and DA
Hello!
Yes, your understanding is correct in part, but the key detail is they are NOT pin-to-pin compatible, even though both use the same 256-pin FineLine BGA (F256) package.
Here is the clear explanation of why Quartus does not allow Device Migration between 10M50DDF256C8G and 10M50DAF256C8G (both MAX 10 50K LE devices, speed grade C8, RoHS-compliant G suffix).
The Critical Difference: Power Scheme (Single vs Dual Supply)
| Parameter | 10M50DAF256C8G | 10M50DDF256C8G | Impact on Compatibility |
| Power Scheme | Single Supply (DAF = Dual + Analog? No: actually Single voltage rail) | Dual Supply (DDF = Dual + Analog) | Different power pin assignments |
| Core Voltage (VCC) | Shared with I/O: only 2.5V or 3.3V | Dedicated 1.2V core | Completely different |
| VCCIO Voltage | Fixed to 2.5V or 3.3V (all banks same) | Flexible per bank: 1.2V ~ 3.3V | Different flexibility |
| Additional Power Pins | Fewer dedicated 1.2V pins | More dedicated 1.2V VCC + VCCA pins | Power/ground ball locations differ |
| Pinout Compatibility | — | Not pin-compatible with DAF | Cannot be swapped directly |
Why Quartus Blocks Device Migration
Quartus Prime's "Device Migration" feature only allows switching between devices that are fully pin-compatible — meaning every single ball (pin) has the exact same function and voltage domain.
- The DDF version has many balls assigned to 1.2V core power (VCC) and analog supply (VCCA).
- The DAF version reassigns those same balls to VCCIO (2.5V/3.3V) or ground.
If you try to migrate:
- Quartus detects the power pin reassignment → migration path is not supported.
- Even if you force the change manually, the design would fail hardware (you would short 1.2V to 3.3V or leave core unpowered → chip damage or no function).
Summary Table – Can You Interchange Them?
| Question | Answer |
| Same package size / ball count? | Yes (both F256) |
| Same logic resources & speed grade? | Yes (identical 50K LE, C8 grade) |
| Pin-to-pin compatible? | No – power pins are remapped |
| Can I use one on a board designed for the other? | No – will damage the device or not work |
| Does Quartus allow migration? | No – migration path is blocked |
| Which one should I choose? | Depends on your board power design: • Single 2.5V/3.3V rail → DAF • Need 1.2V core + flexible I/O → DDF |
Recommendation:
- Check your schematic / power supply design:
- If you only have one voltage rail (2.5V or 3.3V) for both core and I/O → use 10M50DAF256C8G
- If you have separate 1.2V core supply → use 10M50DDF256C8G
- Do not swap them on an existing PCB — it will almost certainly destroy the FPGA.
- If you're redesigning the board, choose DAF for simpler power supply (single rail, fewer components).
If you can share a screenshot of your power supply schematic (especially VCC, VCCIO, VCCA connections), I can tell you immediately which one is correct for your design.
Alternatively, you can visit www.aceicc.com and seek their advice; I got a good answer from them last time.
- Aaron10 months ago
10M50DAF256C8G is a dual power supply device.
Which document did you get that information from?
Your explanation seems to contain many errors.
