Device Migration - does it work with some power pins not connected?
I believe you still have to connect to VCC/VCCINT/GND etc.
Thank you.
- REics4 years ago
Are you sure the pins are not tied together internally? For Xilinx devices, that seems to be the case:
https://support.xilinx.com/s/article/22338?language=en_US- AminT_Intel4 years ago
I am unable to validate that based on other company's device. I would recommend you to refer to our FPGA handbook/device datasheet on your design.
Thank you.
- roffez4 years ago
I have verified and the power pins in the EP4CE55F23 are internally tied together. I have soldered one device on a board designed for a EP4CE40F23 and confirmed it's fully working! (It's not good practice, though. I think I'm going to make a redesign of the board which feeds all power pins, though. This is also what the "Migration Assistant" yields as connections, if you select EP4CE40F23 as base device and EP4CE55F23 as migration device).
