KfirTito
3 years agoDevice configuration failed + CRC error while using .jic file
Hi, FPGA model : C10LP120YF780I7G, Vcore = 1.2V , Vccio = 3.3V (conf dev IO voltage) Flash model : MT25QL128ABB Conf Scheme : AS (x1) , MSEL[3:0] = 1101 (AS, Fast, 3.3V) JTAG Conf : Single Devic...
KfirTito
3 years agoHi , thanks for the fast response
See my comments below :
1. YES
2. How to read the rpd from the flash ?
3. CONF_DONE pin connected to 10K PU resistor according to " Active Serial Single Device Configuration" and also to FET+LED (attached snapshot from my schematics).
4. Regarding the .rpd generation, i can't choose my configuration device, can you pls check if its ok (attached .rpd & cof files)
BTW - After .rpd generate, I cant choose this file in Quartus programmer :
